    Error when using shell extensions and Total Commander
    29 Posts 3 Posters 25.4k Views
    • PoooMukkelP Offline
      PoooMukkel
      After that there are no shell extensions from PowerArchiver available although I checked the box in the settings. :(
        but you should have 32bit ones in TC? PA installs both x86 and x64 shell extensions.
          PoooMukkel
          No. There are no extensions from PA after that.
            run this:
            %windir%\SysWOW64\explorer.exe /separate, /root, c:
            do you see PA shell there now?
              PoooMukkel
              Still no shell extensions from PA.
                PoooMukkel
                May be did you change something in PA2011 12.11 to solve this problem for me? ;)
                  PoooMukkel
                  No… It still does not work. :(
                    PoooMukkel,
                    Sent you a PM :)
                      bumping this thread again, should be fixed in .22
                      let us know
