    Using WIKI for Help
    35 Posts 7 Posters 23.8k Views
    • LuxorL Offline
      Luxor Alpha Testers @spwolf
      and it kind of looks cool too :-)
      It looks a damned site better than some Wikis I have had the misfortune of trying to use in the past that’s for sure.
      I still want to see a larger font though.
      Windows 10 Home 64-bit
        spwolf conexware @Luxor
        @Luxor:
        font is actually +1 compared to our current help :-).
        • LuxorL Offline
          My eyesight isn’t though. ;)
            we can make ± that you can click to get bigger font sizes.
            • LuxorL Offline
              That would be an ideal solution. :)
                i am glad you guys like it…
                • moles42M Offline
                  moles42 Alpha Testers
                  ‘Table of Contents’ issue with font size ???
                  or are you still tweaking…?
                  Windows 10 Pro x64
                  Intel Core i5 3470 @ 3.20GHz
                  8.00GB Dual-Channel DDR3
                    you should have looked before :-)… right now it is still in testing mode
                      better now? luxor? ;-)
                      • LuxorL Offline
                        Yes I can almost read it without my glasses. :D
                            And there is work in progress for main PA:
                            http://attachmentcloud.com/wiki/help:main:basics:adding_files_to_an_archive
                            • moles42M Offline
                              Impressive !
                              Windows 10 Pro x64
                              • LuxorL Offline
                                Luxor Alpha Testers @moles42
                                @moles42:
                                Impressive !
                                Very! :)
                                  davidsplash @Luxor
                                  what i was trying to say to people is what if your internet connection goes down. if say the main server fom t crashes where do u get help on pa if its online
