    Question for everyone
    7 Posts 3 Posters 5.6k Views
      davidsplash
      if i took a snapshot of an archive i.e its binary or something along thoese lines could i recreate the archive exactly, using this data
        if you took an copy of archive, then of course you would have copy of archive.
          davidsplash @spwolf
          what i was trying to say if you took a snapshot of the binary code to that archive could you recreate the archive as it
            mwb1100 @davidsplash
            @davidsplash:
            What is a “snapshot of the binary code” if it’s something different than a copy?
              davidsplash @mwb1100
              basically ever program is made up of binary code in essence if you recreate that code you can recreate for instance an archive. Im asking is it possible to take a snap shot of a powerarchive archive from a snapshot rather than having to have copy of the original archive
                what you are describing is another name to call an copy of archive
                  if you have snapshot/copy of binary code of file, and that file is an archive, then you have copy of archive.
