Edition	Windows 11 Pro
Version	24H2
OS build	26100.2605
Archive inside archive fault
haveing a problem with two archives inside aniother
I click on the archive inside an archive and it wont load up. I belive this heppens with zip and rar wondered if it was me or powerarchiver setting -
Hi Fella,
Are you are using the latest 12.00.53? what OS?
I am on Windows XP Pro with PA Toolbox 12.00.53 and have no problems opening a Zip Archive within another zip archive or 7zip for that matter.
I dont use Rar! so cant help at that level.
so more info about archive?
I found out this problem too and noticed that it happens only when the archive inside another archive is located in a folder.
I’m not sure, but I think this problem happens with all file types.
I’m using PowerArchiver 12.00.59 on Windows XP Pro.I hope this helps to fix the problem.
I can verify this problem, but only – for me – when the zip file is inside a folder inside an archive.
same here.
sorry its taken ages to get back just back from my walking holiday yes thats the fault.
