    How to mount an ISO file (Sorry for asking!)
    19 Posts 4 Posters 14.1k Views
    • W Offline
      wulffra
      Up front: Apologies for asking this question - I rarely use this feature. This is why I have forgotten how I should mount an ISO file.
      Now: I have “Mount as Virtual Drive” in my context menu. Selecting an .ISO file and mounting this as a Virtual Drive, nothing happens.
      I vaguely remember there is something with PA, taskbar, whatever, but frankly speaking, I don’t know. PA is not in my taskbar (there are alread some 14 items there, so I want to keep the number minimized.
      Tried to find the solution here, likely overlooking it, but after a while of searching, I gave up. The menu item Mount as Virtual Drive should work at any time I guess, without having to search for solutions.
      (Sorry for my ‘complaints’, apart from this Virtual Drive thing, PA is a wonderful product!)
      Anyway: How to mount an ISO as Virtual Drive?
      Is there a way to have the context menu work straightaway, at all times ?
      TIA
      • LuxorL Offline
        Luxor Alpha Testers
        @wulffra:
        I have “Mount as Virtual Drive” in my context menu. Selecting an .ISO file and mounting this as a Virtual Drive, nothing happens.=
        That is the way to mount as virtual drive, so you are doing that right.
        @wulffra:
        I vaguely remember there is something with PA, taskbar, whatever, but frankly speaking, I don’t know. PA is not in my taskbar (there are alread some 14 items there, so I want to keep the number minimized.=
        There is an option in PA Starter to mount as a virtual drive, but that shouldn’t make any difference to your first way of doing it.
        It might be worthwhile enabling PA starter just to test if that works for you. If that doesn’t work then there is a problem somewhere.
        What if you mount a virtual drive from within PA burner, does that work?
        Windows 10 Home 64-bit
        • W Offline
          wulffra @Luxor
          Mount is Virtual Drive: nothing is shown in my Folder Tree list - assume PA wud take any free driveletter and then show the title of the ISO.
          I started pastarter.exe. RM-click on the taskbar button show greyed out: "Create New Virtual DVD Device and greyed out “Unmount/remove Device” (of course)
          When RM-Click on the taskbar button, selecting Powerarchiver Burner, selecting the ISO it only shows the DVD-Writer.
          Check for update, there is none (using 12.00.51)
          • LuxorL Offline
            Luxor Alpha Testers @wulffra
            What happens if you run Virtual drive from within PA’s main interface?
            • W Offline
              wulffra @Luxor
              Where to find it? Under Tools ? Nothing there…, mean no Virtual Drive or something… Sorry, this really sounds a bit silly, I know.
              • LuxorL Offline
                @wulffra:
                Doesn’t sound silly at all. Silly would be not asking.
                It depends on whether you are using the classic or modern interface.
                See the examples I’ve posted. 1.Classic 2.Modern
                • W Offline
                  wulffra @Luxor
                  I have the classic version. Clicked on Burner and noticed Virtual Drive. I clicked on that one, it said it did not have the drivers installed. Do you want to download and install them? “Yes” of course. It downloaded the driver (why is not together with PowerArchiver in the 1st place??) and found that now the context menu “Mount Virtual Drive” has gone.
                  I clicked on burner/Virtual Drive and again it said they are not installed. Again download/install.
                  Still nothing.
                  Cud it be blocked by Kaspersky ? (because of a driver). Cud Powerarc.exe to trusted application.
                  Problems… problems…
                  • LuxorL Offline
                    @wulffra:
                    Still nothing.
                    It’s possible that Kaspersky could be blocking it, but I couldn’t say for certain that it is.
                    Anyone else using Kaspersky here that has the same problem?
                    Did you try a computer restart?
                    Think we best wait for one of the PA team to pop in to see what they can come up with for this one.
                    • moles42M Offline
                      moles42 Alpha Testers
                      I’d definitely disable my anti-virus briefly whilst I checked to see if it was causing the issue.
                      Windows 10 Pro x64
                      Intel Core i5 3470 @ 3.20GHz
                      8.00GB Dual-Channel DDR3
                      • W Offline
                        wulffra @moles42
                        Have downloaded Powerarchiver 2012RC4 and installed that. Went to burner and installed Virtual Drive. After that, like all previous attempts… there was a popup saying Patchbeam.com Update Service
                        PwerArchiver Virtual Drive has been installed.
                        bla bla for latst changes.
                        There is no context menu item. It has gone.
                        Strange…
                        • moles42M Offline
                          you mean the ‘mount’ option has gone from the context menu ?
                          if so please check the configuration again and make sure it is still in the ‘shell’ options.
                          Windows 10 Pro x64
                          • W Offline
                            wulffra @moles42
                            Below is selfexplanatory.
                            Oh, I rebooted as well…
                            KIS was temporary shut down to install the VD-driver.
                            Powerarc.exe and PAVD.exe are in the list of trusted applications.
                            Beats me … :confused:
                              so when you click on same Virtual Drive in the menu again, what does happen now? all works fine?
                              It should be in Extraction part of the shell extensions btw.
                              • W Offline
                                wulffra @spwolf
                                Then PA will ask me to download and install again (did this half a dozen of times already)
                                You mean Virtual Drive should be under ‘Extract’ ?
                                have no idea what ‘test’ is btw.
                                but I am afraid it is missing.
                                • LuxorL Offline
                                  @wulffra:
                                  Yes that’s what spwolf means.
                                  @wulffra:
                                  That let’s you test the integrity of archive.
                                  @wulffra:
                                  I’m sure the solution will be found if we keep at it. :)
                                    ok, so go to C:\program files\PowerArchiver and copy those files there (PAVD installation) to your actual PA installation location.
                                    It will then work properly.
                                    • W Offline
                                      wulffra @spwolf
                                      Thanks a lot! That did it.
                                      There was a PAVD2010.exe (14-03-2010) in my F:\Powerarchiver-folder, renamed that one and copied the PAVD2010.exe (02-03-2011) from C:\Program Files (x86)\PowerArchiver to where Powerarchiver is installed (F-drive)
                                      It works now. :)
                                      Again many thanks!
                                        cool, :-)
                                        • LuxorL Offline
                                          @wulffra:
                                          It works now. :)
                                          Great stuff. I knew it would get solved eventually.
                                          Now I only have to try and work out how spwolf figured it out. :D
