    PowerArchiver Burner Write Speed
    3 Posts 3 Posters 3.3k Views
    • K Offline
      Keith Weisshar
      Why does PowerArchiver 12.00.51 only show maximum write speed of 12x when burning to an 16x DVD-R even though Nero can still write up to 16x?
      • moles42M Offline
        moles42 Alpha Testers
        yep confirmed…I’m curious also.
        Windows 10 Pro x64
        Intel Core i5 3470 @ 3.20GHz
        8.00GB Dual-Channel DDR3
          logging it in!
          thanx fellas!
