    Right-Click Burn file to disc bug
    5 Posts 3 Posters 4.6k Views
    • K Offline
      Keith Weisshar
      When I select more than one folder and then right click burn file to disc I get a message folder already exists and then everything is blank in the PA burner. When I right-click a single folder and then burn file to disc the folder directly off the root of disc that I right-clicked is blank in the PA burner but all other files and subfolders are visible. I’m using Windows 7 64-bit with PowerArchiver 2011 RC3.
        Thanks Keith! Fixed in the next release!
          check with RC4 please…
          • K Offline
            Keith Weisshar @spwolf
            Fixed, why is the final release pushed for June instead of May?
              we decided to add new encryption features while we are waiting for new website to be completed
