    Public to create own format
    5 Posts 2 Posters 4.2k Views
      davidsplash
      is it possible for jo public to create a archive format for pa, or does it need specific info on pa to actually do this, as it does with other archivers?
      • RJWaringR Offline
        RJWaring
        Interesting? Why would you want this feature?
          davidsplash @RJWaring
          to create new formats specific to certain file types
          • RJWaringR Offline
            RJWaring
            I understand now, the idea sounds good but im not sure how complicated it would be to create something to allow the user to then make their own formats.
            But who know :)
              one idea is that the plugin system allows for command line archiver programs to run. This happens with total commander though not sure how to get it working with pa with out specific info on how to get something done for pa as it is going to have to be a specific plugin to pa
