    Patchbeam
    18
    9668
      Marc
      hi,
      as on your blog i tried to update to RC2 with patchbeam (163kb) but i don’t works? HELP
      • RJWaringR
        RJWaring
        Check you have Admin rights on the profile. Depending on your OS you have have to authorise via Windows UAC.
        If both of them are fine and no problems, try opening PA again and checking for Update’s Manually.
          Marc @RJWaring
          sir richard,
          yes, i got admin rights, and i tried a manual update. but nothing works :confused:
          • P
            PBMCMLXXI @Marc
            I can confirm that the patchbeam update did not work, it did not find anything to update. Downloaded RC2 direct from site.
            Windows 10 *64 - Latest TP (Fast)
              worked here just fine
              When you tried to update all it showed was the RC1 version?
                Marc @Mili
                PA
                installed version 11.71.04
                available version 11.71.04
                no update
                Patchbeam
                installed version 1.00.10
                available version 1.00.09 ???
                no update
                check for newest beta/official enabled
                  the Beta updates may not be available as of yet, so when upgrading from PA 2010 to PA 2011 please do it via fresh install from our download page at www.powerarchiver.com/download
                    Marc @Mili
                    “check for newest beta/official enabled”
                    so if this function not works, why integrate in PA.
                    then only make
                    “check for newest official enabled”
                    available in the program
                      Hi Marc,
                      keep in mind that the RC version has only been released with Beta version to follow.
                        spwolf conexware @Marc
                        @Marc:
                        PA
                        no update
                        Patchbeam
                        no update
                        PA 2010 users will get update notifications once RC3 is ready…
                        • TBGBeT
                          TBGBe @Mili
                          @Mili:
                          Hi Marc,
                          Sorry, but I don’t understand this.
                          Surely, RC is a Release Candidate
                          Isn’t the “path”
                          • Alpha
                          • Beta
                          • RC
                          • Release
                          :eek: :confused:
                            spwolf conexware @TBGBe
                            @TBGBe:
                            Isn’t the “path”
                            • Alpha
                            • Beta
                            • RC
                            • Release
                            :eek: :confused:
                            We hope to have final version in few weeks, depending on the results of the testing.
                            • RJWaringR
                              RJWaring
                              For those in the Alpha & Development team from seeing something go from Alpha to Release is almost like seeing your kids leave home and do there own thing :-D
                                If i wasnt clear enough Terry, there will be no Betas :-). Mili was probably just a bit too tired.
                                • TBGBeT
                                  TBGBe @spwolf
                                  Yeah, I had already guessed that.
                                  Just opens up the Patchbeam questions (Release and Beta) …
                                  Unless Mili was talking about PA 13.xx betas :p
                                  • D
                                    davidsplash
                                    p[atchnbeam does not exit after update finishes
                                    • TBGBeT
                                      davidsplash, seen this when Patchbeam updates itself. Do you know what version of Patchbeam do you had before update?
                                      Check the current file version in [ProgFiles]/Patchbeam.
                                      • D
                                        davidsplash @TBGBe
                                        have the latest
