    Pae problem
    14 Posts 5 Posters 7.0k Views
    • K Offline
      Kaiohshin
      My pae file is corupted, it says wrong password but the password is the same. is there any way to recover my data? isn’t there a temp of the file somewhere?
      • LuxorL Offline
        Luxor Alpha Testers
        There is no way to recover data from a pae.
        Are you a 100% sure that your password is correct?
        Windows 10 Home 64-bit
        • K Offline
          Kaiohshin @Luxor
          damn…. i’m sure
          cry cry cry to infinity
            unfortunately, since it is encrypted, recovery is impossible. Was it stored on CD/DVD?
            • K Offline
              Kaiohshin @spwolf
              nop
              it’s on my laptop,
              “error: the password is invalid” is what it says
              any other way to open it?
              D spwolfS 2 Replies Last reply Reply Quote 0
                davidsplash @Kaiohshin
                can you try the version of pa you created the pae in please cas it could be the new version your using or an old version that has a creation bug in it
                  spwolf conexware @Kaiohshin
                  @Kaiohshin:
                  nop
                  it’s on my laptop,
                  if encrypted file is corrupted, there is no way.
                    davidsplash @spwolf
                    wouldnt it be a good idea once pa has created the pae to say if the files are ok in the pae
                    S LuxorL 2 Replies Last reply Reply Quote 0
                      Serhiy @davidsplash
                      @davidsplash:
                      You’ll see if they “are ok” after decryption with a valid password.
                      • LuxorL Offline
                        Luxor Alpha Testers @davidsplash
                        @davidsplash:
                        There is a “test” button for that very purpose.
                          davidsplash @Luxor
                          true but if a window came up saying all files have been encrypted with this password and they are ok it would confirm the encrytion has worked. How many people actually test an archive out after they created it?
                          Very few
                          if there was a problem with the archiver it can be addressed straight away.
                          • LuxorL Offline
                            @davidsplash:
                            Well I can’t speak for others but it’s something I do every time.
                              if the file was not created right, you would get an error.
                                davidsplash @spwolf
                                true but what i was thinking that if ther was an end screen saing encryption ok and what password it would help people who input a password and need reminding. This will sort out any problems found if a person has actually used a differnt language keyboard layout at the time and not realised it.
