    Issues with PA2011 and IE9 RTM
    6 Posts 3 Posters 5.8k Views
    • skypxS Offline
      skypx
      Not sure if this was reported before but there seems to be an issue with Facebook and script issues. I get the following popup even with option to report script errors disabled in IE9’s settings. It may be a coincidence but it started today after installing IE9 RTM yesterday.
      This issue presents itself after PA2011 automatically checks for updates.
      ASUS Crosshair VII Hero
      AMD Ryzen 9 5700X
      T-Force DDR4 3600 32GB
      Samsung 970 EVO 2TB
      GTX 3080ti
      Win10 x64
      • skypxS Offline
        skypx
        A manual check for updates will reveal the same script errors.
        AMD Ryzen 9 5700X
        Samsung 970 EVO 2TB
        GTX 3080ti
        Win10 x64
        • moles42M Offline
          moles42 Alpha Testers
          confirmed !
          Windows 10 Pro x64
          Intel Core i5 3470 @ 3.20GHz
          8.00GB Dual-Channel DDR3
            so much for testing Microsoft!!! :-)
              fixed… thank you!
              • skypxS Offline
                skypx @spwolf
                @moles42:
                confirmed !
                fixed… thank you!
                Cool. Thanks guys.
                AMD Ryzen 9 5700X
                Samsung 970 EVO 2TB
                GTX 3080ti
                Win10 x64
