It doesn't work
Hi guys i heard some truly great things about powerarchiver, i’m using winrar at the moment but i can’t compress anything: 25 mb stays 25 mb am i doing anything wrong?
Hope you guys can help me out
thanks already
jhonnie69
What format do you use?
If you are talking about WinRAR
please check “Compression method” option.
If it is set to “Store”,
it will NOT compress.
it just creates an archive without compression!
I recommend using “Best” and “Create solid archive” options.
Hope this will help,
Try PowerArchiver!
http://www.powerarchiver.com/download/You will love it! ;)
PowerArchiver has a modern easy-to-use interface, and provides support for most compressed and encoded files, as well as access to many powerful features and tools. I believe that PowerArchiver is the most complete archive utility available today.
Try it!
Thanks,
