    PBS problems
    7 Posts 4 Posters 3.6k Views
      Socrates Banned
      I downloaded and installed 2011. Loved the new options. Looked great. Loaded fast. Very optimistic.
      But my PBS (backup) wouldn’t run. Well. t appeared to run, but didn’t do anything.
      Initially I tried running it as was.
      Then I “edited” it (not really . . . just opened it and made a faux change and resaved. Still no luck.
      Any user find the same problem? Did you find a solution?
      • moles42M Offline
        moles42 Alpha Testers
        backup script appears to be working fine on my system…just tested it on a couple of scripts I have.
        sorry I know that doesn’t help you.
        Windows 10 Pro x64
        Intel Core i5 3470 @ 3.20GHz
        8.00GB Dual-Channel DDR3
        • LuxorL Offline
          Luxor Alpha Testers
          All my PBS are working ok.
          Do you have the same problem with a new PBS or is it just your old ones that are not running?
          Windows 10 Home 64-bit
            Socrates Banned @Luxor
            It is an old one. But I did open it in 2011 to look at new setting . . . and then resaved it.
            Perhaps I should have started from scratch.
            Didn’t want to try the others since my others reset the archive bit . . . which would foul up my backups.
            When I get the chance, I will try to rebuild them from scratch – although for some, that could be a bit time consuming.
            Thanks.
              Please send us an older script which would not work in PA 2011 to support @ conexware dot com and we will take a look
              my old scripts seem to be working fine as well
                Socrates Banned @Mili
                I did. However, since they are now 2010 scripts again,maybe it won’t help.
                I need those scripts to move files back and forth from home to work . . . so I had to remove 2011 'til I know this is fixed.
                Thanks for your quick and helpful response.
                  Got it! Thanks for that!
                  Taking a look now will report via email.
                  Anyone else have issues with older PBS scripts, let us know
