    Slow opening / Slow unpacking start / Slow closing
    25 Posts 5 Posters 18.4k Views
    • G Offline
      gan @Mili
      Thank you Mili, i checked both the desktop and laptop, but neither of them had a floppy icon under computer. I also checked device manager and did select to show hidden devices, but no floppy listed there as well.
      gan
        swenak @gan
        I dont have flopy drive, I disable SD card slot, I switch to standard view of PA and here is video (is not public, only for you).
        http://www.youtube.com/watch?v=fZMeVHuG45U
        Peter
        PS: Yes, it is latest Air and NO, it is not virtualisation, it is native using of W7 on MBA and NO, I dont use dual boot, only W7.
          spwolf conexware @swenak
          well I can tell you now that PA 2011 will be indeed slightly faster for you - for instance, that small “pause” when in shell, will be gone because we improved our keycheck by 0.3-0.5 seconds. So in your test, shell should be “instant” in the future, when everything is cached.
          Main PA will be also faster by same 0.3-0.5 seconds as well, although it might be less noticeable because overall it is slower to open than shell.
          Slowness is not due to what people usually think - skins or some other fancy features like backup, burner, ftp or any of that. We load all of that dynamically, so nothing is loaded during startup.
          Where “slowness” comes from is due to the fact that we have to use custom controls in order to add full unicode support to application (which is essential), and thats where major difference is between PA 2007 for instance and any version after that.
          For instance, PA 2007 will load in 1 sec, PA 2010 in 1.6s and PA 2011 in 1.3 seconds, on the same computer, and it is all due to that unicode support which requires slower controls.
          After we are done with 2011, we will start process of migrating to newer version of Delphi, which should bring speed back to PA 2007 levels because unicode is built in and we can get rid of some custom controls, but that requires a huge amount of work and might bring some bugs of it own, since we have to rewrite some major parts of PowerArchiver.
            p.s. that SSD certainly speeds things up!
              email us at support at conexware dot com to get access to alpha which you can test…
              As I said, it is 0.3s-0.5s speed up on very fast computers, and possible a lot of speed up on VERY old systems, but I wonder if it will be noticed on average computer.
              Shell is definetly noticable, since there is not slight delay that is there in PA 2010.
              On my own computer, 1.45s for PA 2011, 1.8s for PA 2010, with AV running.
