    Patchbeam problem
    5 Posts 2 Posters 6.5k Views
      davidsplash
      sometimes when trying to install pa it sayes pa process still running and i have to press retry to get it working all i did was ask it to check for updates and update
        this has been fixed in newer version of patchbeam, basically we expanded the delay needed to close the app.
          davidsplash @spwolf
            davidsplash @davidsplash
            problem still exists it would be better if instead of asking you to retry to have an accept button instead so you dont think there is a major problem
              spwolf conexware @davidsplash
              @davidsplash:
              new version will be in PA 2011, not in current PA2010.
