    Command prompt problem
    6 Posts 3 Posters 4.8k Views
    • K Offline
      kolbaszgyar
      I can delete back a lot of characters in the command prompt window. e.g: i am typing dir then the del button a can delete back a lot of characters. can it be fixed anyway ?
        are you talking about toggling Ins key? seems so…
        • K Offline
          kolbaszgyar @spwolf
          Hi, no I do the followings:
          enabling command prompt window in view menu
          it brings up this standard text:
          Microsoft Windows [verziószám: 6.1.7600]
          Copyright © 2009 Microsoft Corporation. Minden jog fenntartva.
          C:>
          if i start to press the delete button i can delete the text back. normaly it should not happen.
            i understand now, thanks… Mili will write it up and we will see what can we do about it…
              Logged in! Thanks kolbaszgyar
              • K Offline
                kolbaszgyar @spwolf
                thanks a lot. i have identified an other problem with Preview window. the problem is that for certain avi files no sounds available. I guess you were using ATView (UniversalViewer) component and the error should be on that level as if i am opening the file via Universalviewer no sounds as well. This is a small an annoying problem.
                if required so I can open a new ticket for this.
