    Extracting large tar files (more that 4GB?) does not work, incomplete extraction
    4 Posts 3 Posters 7.6k Views
    • E Offline
      ehoffman
      Hello
      I think I found a bug.
      I have a .tar.bz2 file (I also tried with the standalone .tar version with same result), that is 2.5GB (the uncompressed .tar is 8.1G).
      I extract the files from the .tar.gz, and only get a partial extraction. Trying to extract the ‘missing’ files manually, the file do get extracted, but are then extracted as 0-bytes file.
      The archive (.tar.gz) I have problem with can be downloaded from Backtrack web site (a Linux distribution). At www.backtrack-linux.org, in the download section, it’s the ‘BackTrack 4 R1 Release VMware Image’. The archive is 2.5G.
      I tried with another decompressor and that worked fine.
      This is with PA 2010 11.61.06
      Regards
      Eric
        MOving to PowerArchiver Support - not reported as a PACL fault (although a similar size limit may apply to PACL as well).
          @ehoffman:
          Hello
          Regards
          Eric
          i am not sure what is the size limit in our support for TAR, it could be less than 8 GB easily…
            TBGBe @spwolf
            I noticed &zip has only recently added support for TAR > 8GB. So if there is a current limit, this could be an interesting wishlist (for both PA and PACL)?
