    Tar gz extract issue 11.64
    4 Posts 2 Posters 4.2k Views
    • P Offline
      Pimon
      I upgraded to the latest version of the program (11.64.01) and i am having the same problem as described above.
      I am trying to extract a gzip file but i can’t see any files after the extraction is complete ony the folders.
      I tried with the previous version of the program and it worked perfectly. The problem came after i upgraded to the latest version.
      Has your issue been solved and if so how?
        what is the previous version that was working correctly for you? And can you send us that file (as long as it is smaller than 2-3 MB) to support at conexware dot com and reference this thread? thanks!
        • P Offline
          Pimon @spwolf
          spwolf,
          It worked corrrectly with version 11.50.37 (03/2009).
          I am using Windows XP Media Center Edition with SP3 installed.
          I will send you the file by email.
            thanks, I opened bug report for devs to take look at and we will let you know more once we have some details.
