    Iso mount
    25 Posts 6 Posters 16.8k Views
    • I Offline
      itechlang
      I am having an issue to mount iso images on my Win 7 x64.
      I am getting the following error message:
      “An error occurred during installation of the device!”
      The same iso file in the same folder can be mounted without any issues on my Vista x64 though so it is not related to the iso file.
      I have the same version of PowerArchiver including PAVD installed on both the machines.
      Any known issues with Win 7 and Virtual drive?? Or any other known issues around this?
      Thank you.
        is it that specific iso or all isos on that computer? There are no similar issues that I know of, a lot more people use PA with Win7 compared to Vista.
        I 2 Replies Last reply Reply Quote 0
        • I Offline
          itechlang @spwolf
          All iso’s I have tried fail. :confused:
          • I Offline
            itechlang @spwolf
            I got a post from moles42 about my topic but I cannot see in the forum.
            moles42 was asking this:
            just wondered if you were using any other conflicting virtual drive software on your system?
            Actually it is funny because I am using another virtual drive (UltraIso) on the machine where PAVD is working but I do not have any VD software on my Win 7 machine where PAVD is not working!
            I just tried PAVD on another fresh Win 7 x64 install and it does not work either!!
            So it is working on my Vista Home premium x64
            but not working at all for any iso’s on my Win 7 Ultimate x64 and Win 7 Home premium x64.
            How come? :(
            Are you sure it is working on Win 7 x64??
            FYI, I have been testing the same versions on all my systems i.e. PA 11.62.04 + pastarport13004
            Please help!!
              yes, it works on all of our win7 computers - i am typing this from win7 64bit ;-).
              Can you try deleting pavd2010.exe from PA folder and then reinstalling it again?
              • I Offline
                itechlang @Mili
                I have tried this many times but still not working.
                • moles42M Offline
                  moles42 Alpha Testers
                  sorry ‘itechlang’ I did post that question but then deleted it thinking it was irrelevant to your problem anyway…I’ve been searching for a solution to your problem today but upto now still haven’t come up with anything sorry.
                  have you tried another piece of software on your W7 system to mount an iso apart from PA?
                  and yes it works perfectly on my Windows 7 Ultimate x64 system.
                  Windows 10 Pro x64
                  Intel Core i5 3470 @ 3.20GHz
                  8.00GB Dual-Channel DDR3
                  • I Offline
                    itechlang @moles42
                    moles42,
                    yes I tried UltraIso on 1 of my Win 7 systems and it works.
                    • I Offline
                      itechlang @itechlang
                      Anyone can help? I cannot be the only one having this issue.
                      • moles42M Offline
                        Far be it from me to promote alternative software but to try and solve this issue can you try using ’
                        DVDFab Virtual Drive’ http://72.55.191.8/download/DVDFabVirtualDrive1114.exe to see if it works on
                        your system?
                        it works in the same manner whereby you mount the iso files as PA does…
                        I’ve just tested it and it works fine on my W7 x64 system.
                        apologies to management for seemingly promoting alternative VD software…:o
                        what I did like about the program though was when you actually closed it down it removed the virtual drive as well…a facility I did find much to my liking…any chance PA can have this option guys ???
                        Windows 10 Pro x64
                        • RJWaringR Offline
                          RJWaring
                          Moles42! We might have to beat you for this clear breach in member’s rulling! Now walk away with your head in shame…
                          PowerArchiver Rules… “in case management read this”
                          • moles42M Offline
                            sorry guys…was only trying to help this poor guy out…:o
                            give me my 50 ‘lashes’ and let’s move on…:eek:
                            Windows 10 Pro x64
                              After everything PA has done for you Moles……
                                :D
                                All joking aside,
                                itechlang, please do let us know the results of using the VD software moles posted and thanks Moles for looking into it!!
                                We haven’t had any other reports of constantly failed ISO mounts on x64 so this has to be specific.
                                Let’s see how this works
                                • I Offline
                                  itechlang @Mili
                                  Hi guys!
                                  So I tried DVDFab Virtual Drive as I had tried UltraIso before and both are working perfectly.
                                  So I am sorry to tell you guys but I am afraid the issue is on your side.
                                  I have 2 machines running Win 7 x64 and PAVD is NOT working on both.
                                  I have one running Vista x64 and it is working.
                                  You must admit it is a weird coincidence.
                                  For me there is something related to Win 7 x64.
                                  DVDFab VD and UltraIso are working like a charm on all my machines regardless the OS.
                                  Hope you will sort this out soon.
                                    dragon57
                                    I have a brand new Win 7 64-bit install here and the PA iso mount works fine. Sorry, I was hoping I could help diagnose your problem :(.
                                      which windows 7 version do you have installed?
                                      • I Offline
                                        itechlang @Mili
                                        Win 7 x64 Home Premium - not working
                                        Win 7 x64 Ultimate - not working
                                        Vista x64 Home Premium - working
                                        Thanks.
                                          maybe there is some software or some option that is common to those two win7’s that dont work?
                                          • I Offline
                                            itechlang @spwolf
                                            Yes maybe but 1 machine is brand new and the other one is 2 years old and I have never had any issues with other Virtual Drive software.
                                            How come it is just PA Virtual Drive being not working whereas others like UltraIso, DVDFAb or even PowerIso are working?
                                            There is probably something on those 2 machines that PAVD does not like, maybe it is the brand. :)
                                            They are both HP laptops.
                                            HP Pavilion dv7-3173ca
                                            http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01980766&tmp_task=prodinfoCategory&lc=en&dlc=fi&cc=fi&lang=fi&product=4125929
                                            HP Pavilion dv9700 CTO
                                            Unfortunately the HP website has no longer the detailed specifications on this one.
                                            Thanks anyone for any help with this.
