    Drag&Drop archive to PA doesn't open the archive
    8 Posts 4 Posters 10.1k Views
    • K Offline
      klumy
      If I drag an archive to PA, PA won’t open the archive in PA
        Serhiy
        When PA is running in “Classic viewing style” and you drag an archive on to Main Window, PA doesn’t open it!
        But when PA is running in “Explorer viewing style”, it copies an archive to the currently open folder like in Windows Explorer.
          spwolf conexware @Serhiy
          There were some problems with automatically opening those archives, it was done in one of the previous releases, not in 9.1. I will check whats the status of this with ivan…
          • guidoG Offline
            guido
            Has anyone tried the steps that are explained in the help?
            Step 1. Navigate to the archive using My Computer or Windows Explorer
            Step 2. Click on the archive and, while holding down the left mouse button, drag the mouse pointer over an empty PowerArchiver window
            (if you already have opened an archive in the PowerArchiver, it will not open the file, but instead add that file to the currently open archive).
            Step 3. Release the left mouse button to open the selected archive.
            On my version it doesn’t work. Is D&D Still disabled?
            Guido
            Windows 11 Pro ENU x64
            Intel Core I7
            32 GB RAM
              spwolf conexware @guido
              Yes it is. I will merge this thread with one previously posted on this subject.
              It is still on the list for 9.2.
                spwolf conexware @spwolf
                9.11 should solve this as well.
                • guidoG Offline
                  guido @spwolf
                  My problem is fixed.
                  Guido
                  Intel Core I7
                  32 GB RAM
                    great, I am closing this one.
