    Win 7 and Admin issues
    6 Posts 2 Posters 5.6k Views
    • drteethD Offline
      drteeth
      I run PA in admin mode all the time and have tweaked UAC not to show prompts for admin accounts (‘yes’ is default).
      I do this as I install into the \Program Files folder a lot.
      However, if I open PA by double-clicking on an archive; it does not open with admin privileges and the copy fails. I have to open PA manually and use the MRU list.
      Can PA be made to run with admin privileges when opened by double clicking an archive?
      Cheers
      DrT
        How did you make PA open with admin priv.?
        If you got to powerarc.exe and right click on it> Properties> Compatibility> Priviledge Level> Run as Admin, this works properly… It is Win7 feature, not something we influence.
        • drteethD Offline
          drteeth @spwolf
          I right-clicked the icon and properties > shortcut tab > advanced > select run as admin box.
          Will do this for the file itself. Thanks for the tip. BTW, CTRL + L.Shift + double click does it as a once only thing.
          Cheers
          DrT
            that works for me for icon… but try file in any case.
            • drteethD Offline
              drteeth
              Changing the file in stead of the shortcut did the trick.
              DrT
                cool ;-)
