    Rar problem
    12 Posts 5 Posters 7.2k Views
      davidsplash
      if you use the windows explorer shell extentions to open a rar file of aabout 13gb with powerarchiver it does seem to work checked the same file out with winrar and it opens it no problem from shell extentions. so it has to be a pa fault.
        @davidsplash:
        creating a 13 gig RAR to see what’s up.
        further details would help
          davidsplash @Mili
          well in truth it was about 23 gbs but for testing i then went back to 13 and still had the problem as for my detauils here goes same as before used shell extensions to open the rar file with pa and the progress bar comes up but nothing. if you use winrar it opens the file and extarcts the file which pa was unable to do
            am I out of the loop in regards to a previous issue?
            What’s the problem?
            are you extracting or opening via shell?
            Which shell option are you using?
            If extracting from main PA, how are you extracting it?
            at it works fine here
            • moles42M Offline
              moles42 Alpha Testers
              David…just curious to know roughly how long did it take you to create a 23 gig rar file please?
              I only ask because I was testing similar example earlier today.
              Mike.
              Windows 10 Pro x64
              Intel Core i5 3470 @ 3.20GHz
              8.00GB Dual-Channel DDR3
                davidsplash @moles42
                it ws already on a disk i had and i just tried to extarct it with pa and it failed
                  spwolf conexware @davidsplash
                  @davidsplash:
                  you need to find out more about that file… it is not because of the size… does it open when you doubleclick on it?
                  D spwolfS 2 Replies Last reply Reply Quote 0
                    davidsplash @spwolf
                    the probelm is still there some rar files open ok in winrar but not in pa winrar this its got something to do with there unrar.
                      spwolf conexware @spwolf
                      you need to send us more info… “some rar files open ok in winrar but not in pa winrar” means really nothing.
                      Best would be to send us support email and upload the files to our ftp once we send you info via support. Without it, we can not do anything.
                        davidsplash @spwolf
                        will truy and redig out the file when i have time.
                        • P Offline
                          papitas66 @davidsplash
                          Did you ever get it resolved? Same thing has started happening to me intermittently
                            davidsplash @papitas66
                            not really though reformating my computer and reinstall windows 2000 solved the problem. I must thank pa for sticking by windows 2000 theybare a life saver
