    7z shell extensions
    11 Posts 4 Posters 10.8k Views
      davidsplash
      if i slect a filke say 8 mb tand click on 7z name7z for example it starts to work then slows right down after about 58 %
      however if i select 7z + options and then click on the 7zi file is created ok no problems
      the file i’m archiving is a setup.eng (avast antivirus setup file)
      I’m using windows 98 se
        does it just slow down and completes or does it hang there? If it completes, is it the same size as in + options or? It is possible that using it directly activates the ultra option which is slower, while + option uses something else?
          davidsplash @spwolf
          it slows down and hangs i nbever got further than 58%
          the + option uses normal compression and works fine
          D spwolfS 2 Replies Last reply Reply Quote 0
            deipotent @davidsplash
            Have you tried compressing it with the + option and then using all the avaliable compression levels ?
              spwolf conexware @davidsplash
              @davidsplash:
              Try using + Option and Ultra compression - what happens then?
                spwolf conexware @spwolf
                p.s. I could not reproduce this with my copy of Avast setup
                  davidsplash @spwolf
                  does pa use ultra for its shell extensions as normal work fine from the _option
                    TBGBe @davidsplash
                    When checking Options / Configuration / compression profiles / create new
                    the “profile1” for 7z is set to Ultra so this may be the default which is used in shell context menu.
                    The help file says
                    When you first install PowerArchiver, it will create a default compression profile for each format. These profiles can not be deleted and are always saved in PowerArchiver.
                    What are the settings for these default profiles that PA creates?
                      spwolf conexware @TBGBe
                      Default seetings are maximum always (Ultra in this case), but David should check first if Ultra works from + Options, before any conclusions are made.
                      For me, Avast setup in question works fine at all 7zip settings…
                        deipotent @spwolf
                        Because PA uses the 7zip DLL (ie. 7z.dll) for compression/decompression of 7-zip archives, another thing to try would be to see if the 7-zip archiver itself has any problems compressing Avast.
                        If it does then it is most likely a problem with the 7zip DLL, otherwise it is likely to be a problem with the way PA integrates with 7z.dll.
                          davidsplash @deipotent
                          ultra is the problem would it not be best to have normal used instaed of ultra if the user wants ultra to add it themselves.
