    Using Write Multi_Volume ZIP
    2 Posts 2 Posters 4.0k Views
    • J Offline
      jeff_tyr
      I am trying to zip a large group of files (25) gigs. This is done with encryption and the final size is around 16 gigs. I would like to break this up into 4.6 gig files so I may burn them to disks for mailing. I have tried to use the Write Multi-Volume ZIP feature but it creates another single zip file slightly larger that the original zip file. What am I missing here? Thanks,
        Under Options Tab on the “Add Files” window did you select the “Multiple Disk Spanning” size to “DVD” or to “custom”?
