    Installation glitch ?
    13 Posts 4 Posters 6.6k Views
    • moles42M Offline
      moles42 Alpha Testers
      downloaded the latest update as indicated (11.60.26)
      but on installation attempt it informed me I already had a more recent version already installed on my system…(11.60.25)…a glitch perhaps or do I need to do another ‘clean’ installation ?
      Windows 10 Pro x64
      Intel Core i5 3470 @ 3.20GHz
      8.00GB Dual-Channel DDR3
      • LuxorL Offline
        Luxor Alpha Testers
        Where did you find the link for this version moles42?
        I can’t seem to find it anywhere.
        Windows 10 Home 64-bit
        • moles42M Offline
          I was notified of it by ‘Twitter’ as admin generally does these days…it normally means download from the link http://dl.powerarchiver.com/2010/powarc1160.exe
          this was the twitter message…
          Here you go - 11.60.26, very minor fixes - column size save in explorer, hidden/system folders in backup, 7zip span detection in shell
          Windows 10 Pro x64
          • LuxorL Offline
            Luxor Alpha Testers @moles42
            Yes I saw the twitter post via RSS feed but there was no link in it. A link for 11.60.25 is the last link I see on the twitter page.
            The link you supplied gives me the same message as in your post.
            • moles42M Offline
              seems I was a little over keen maybe to update…generally means download from the normal link…my mistake Luxor…sorry about that.
              Windows 10 Pro x64
              • LuxorL Offline
                No worries mate. :cool:
                  Twitter page updated with link :)
                  • moles42M Offline
                    many thanks Mili…:)
                    Windows 10 Pro x64
                    • LuxorL Offline
                      Thanks Mili :)
                      • moles42M Offline
                        hey ‘Luxor’ what part of Scotland are you from if you don’t mind me asking?
                        I’ve only ever been to Glasgow,Edinburgh,Inverness,Calandar and Fort William from memory…did some traveling through there many years ago…after my first trip there back in the eighties I fell in love with the place…:)
                        apologies for digressing the thread.
                        Windows 10 Pro x64
                        • LuxorL Offline
                          Sent you a PM as that’s not for the forum. :D
                          • B Offline
                            Big_Boss @Luxor
                            I’m a little confused. :D Are those versions linked in Twitter like .26 stable versions or are they experimental/beta or something? Was just wondering whether I should update to those version or just use whatever is available on the Download page.
                            • LuxorL Offline
                              Luxor Alpha Testers @Big_Boss
                              I would say stable but you may want to wait for confirmation of that. 11.60 Final was nearly 2 weeks ago and it has been a couple of bug fix releases since then AFAIK.
