    System and hidden files
    5 Posts 3 Posters 4.9k Views
      Socrates Banned
      I cannot see the system and hidden files when trying to build pbs file – even though I have the system and hidden files option checked.
      This has been a problem for the last three updates.
        when selecting files to be backed up you mean in select files/folders window? or?
        • LuxorL Offline
          Luxor Alpha Testers @spwolf
          I can confirm that one.
          Hidden files and folders is not showing anywhere that it should be as far as I can see.
          Not in selected files/folders window, neither in add files from PA itself and not with Advanced add window either.
          Windows 10 Home 64-bit
            should be showing now in .23 in all places that have new control for showing files/folders (which is where it did not show previously)
            • LuxorL Offline
              I can see them now. :)
