    PA 11.60.23 lost all my shell right click
    36 Posts 8 Posters 28.9k Views
    • ScolpyS Offline
      Scolpy @spwolf
      you dont have it? If you do, let me know what is its date!
      I haven’t this :)
        spwolf conexware @Scolpy
        well thats interesting… run installation again and select repair… fixed?
          what OS are you using?
          ScolpyS 1 Reply Last reply Reply Quote 0
          • ScolpyS Offline
            Scolpy @spwolf
            Windows Vista.
            I repaired that and the file is now existing the problem solved :)
            Thanks for the amazing quick replay and I want to indicate that I happy customer since 2008 ;)
              @Scolpy:
              Windows Vista.
              thank you :-).
                TBGBe @spwolf
                Catching up.
                I don’t have pashell.dll (nor is pashlext.dll) in PA folder :eek:
                Although that explains the problem of no shell, it doesn’t explain why the dll is missing - should I try re-install now or is there more info/checking needed.
                  yeah, repair installation…. XP SP3?
                  • drteethD Offline
                    drteeth
                    Repair installation also needed Win 7 32 bit RC (7100).
                    DrT
                      Repaired.
                      Shell Menu is back.
                      Yes, XP SP3 - I would have said if my signature was wrong ;-)
                        spwolf conexware @TBGBe
                        @TBGBe:
                        Repaired.
                        Shell Menu is back.
                        we have updated our installer to latest release, it seems as if this caused the issue, but it beats me what the issue actually is… because it works fine on all of computers, no matter what we try to do to cause the issue.
                          Here is regressed installer:
                          http://www.powerarchiver.com/test/release10/powarc1160final.exe
                          please someone try it out ASAP so we can roll this out… check if dll works after it and what date is it!
                          • LuxorL Offline
                            Luxor Alpha Testers @spwolf
                            Downloaded, installed and no problems.
                            pashlext.dll Date 17/10/2009
                            Windows 10 Home 64-bit
                              we have updated the installer on the site, so if anyone has this issue again, just re-download PA.
                                TBGBe @Luxor
                                Also no problems with this update.
                                Pashlext.dll
                                • before 13 October 2009, 21:50:52
                                • after 17 October 2009, 18:26:08
                                  cool, weird stuff hits you when you least expect it :-)
                                  • guidoG Offline
                                    guido
                                    latest web update fixes my shell ext. too.
                                    Had no Pashlext.dll before.
                                    Windows 11 Pro ENU x64
                                    Intel Core I7
                                    32 GB RAM
