    PA 11.60.23 lost all my shell right click
    36 Posts 8 Posters 26.4k Views
    • LuxorL Offline
      Luxor Alpha Testers
      Just noticed that all my right click shell options had disappeared. I had to uninstall PA and do a fresh install before I could get them back. Just a heads up in case anyone else has the same problem.
      Windows 10 Home 64-bit
        Ouch - I’ve lost my PowerArchiver shell extensions as well.
        I am sure they were there with PA.11.60.20 and have disappeared with web update to PA.11.60.23.
        I have tried toggling the enable shell option; I have modified the options to just use sub-menu but still missing.
        Note: I do not know if they were present before I reset to default for the disk error message problem as I hadn’t tried shell after update. I have also rebooted a few times since the update.
        I have not reinstalled (yet) in case any further checking is needed - can probably last a day or so without shell (but not longer) :p
        LuxorL spwolfS 2 Replies Last reply Reply Quote 0
        • LuxorL Offline
          Luxor Alpha Testers @TBGBe
          Yep tried all that myself, nothing worked.
          MarcFouM 1 Reply Last reply Reply Quote 0
          • MarcFouM Offline
            MarcFou @Luxor
            I didnt lose my ext. but they were non-functional after the update. I reinstalled it a second time (download from site) and got the functionality back.
            • drteethD Offline
              drteeth
              Confirm all extensions lost here with release version.
              Toggling the enable shell option failed here too.
              Uninstall and reinstall fixed it.
              DrT
                spwolf conexware @TBGBe
                @TBGBe:
                check the date on pashell.dll in your PA folder.
                We actually were investingating something similar in RC versions, where it seemed as installer was not replacing shell dll if it was in use and it needed restart/reboot.
                But when we actually tested against it, it seemed to be replacing dlls without restart, even when they were in use (which should happen with Restart Manager in Vista/Win7 but not in WinXP).
                  all of you restarted your computers after the update, right? Thanks :-)
                  • drteethD Offline
                    drteeth
                    No as never had to in the past; i.e. never (ever <g>) got a message box saying I had to.
                    DrT</g>
                      spwolf conexware @drteeth
                      @drteeth:
                      DrT</g>
                      what OS?
                        well maybe it was not the same issue i am assuming it is, although it seems so… lets see what terry says :-)
                        • MarcFouM Offline
                          MarcFou @spwolf
                          I didnt restart. I downloaded and installed on top of the existing and poof! All was well. Win7 Ultimate x86.
                          • moles42M Offline
                            moles42 Alpha Testers
                            strange Marc…I tried that but encountered an installation error and it removed the installation files once again leaving me with my existing version.
                            I had to do a clean installation and all was fine.
                            Windows 10 Pro x64
                            Intel Core i5 3470 @ 3.20GHz
                            8.00GB Dual-Channel DDR3
                            • LuxorL Offline
                              Luxor Alpha Testers @spwolf
                              Yes first thing that I did when I noticed it, made no difference though.
                              • ScolpyS Offline
                                Scolpy
                                After I upgraded to v11.60.23(2010 final version) I saw that when I clicked on mouse right click the options(such as “Extract to…” and etc) are disappearing.
                                why that problem happen and how can I solve it?
                                Best Regards,
                                Yonatan
                                spwolfS 6 Replies Last reply Reply Quote 0
                                  spwolf conexware @Scolpy
                                  try restarting your computer and see if that helps - if not, reinstall and it should work fine.
                                    it would also be very helpful to us if you let us know what is the date of pashell.dll in PA folder, before you do any of the above :-)
                                    ScolpyS 1 Reply Last reply Reply Quote 0
                                    • ScolpyS Offline
                                      Scolpy @spwolf
                                      I haven’t this file in C:\Program Files\PowerArchiver :O
                                        pashlext.dll?
                                        • ScolpyS Offline
                                          Scolpy @spwolf
                                          pashlext.dll?
                                          Yea.
                                            you dont have it? If you do, let me know what is its date!
