    Extracting .rar archives via right click not working
    11 Posts 5 Posters 8.3k Views
    • skypxS Offline
      skypx
      With the last rc (rc5?), I could extract spanned .rar archives via right click without any issues, no matter what part was selected. Now with the latest version (11.60.22) all I get is a quick flash of the extracting process, but then the window closes, and the file is not extracted. To extract the file I have to open one of the spanned .rar archives. I am using W7 64bit RTM. And yes, I did a clean install of the latest version.
      ASUS Crosshair VII Hero
      AMD Ryzen 9 5700X
      T-Force DDR4 3600 32GB
      Samsung 970 EVO 2TB
      GTX 3080ti
      Win10 x64
      • skypxS Offline
        skypx
        I am also unable to extract a single .rar archive via right click.
        AMD Ryzen 9 5700X
        Samsung 970 EVO 2TB
        GTX 3080ti
        Win10 x64
        • moles42M Offline
          moles42 Alpha Testers
          bug confirmed…
          I’m also using W7 64bit RTM.
          Windows 10 Pro x64
          Intel Core i5 3470 @ 3.20GHz
          8.00GB Dual-Channel DDR3
          • skypxS Offline
            skypx @moles42
            @moles42:
            bug confirmed…
            Thanks moles42. ;)
            AMD Ryzen 9 5700X
            Samsung 970 EVO 2TB
            GTX 3080ti
            Win10 x64
              we’ve noted it, thanks!
              • NarutoN Offline
                Naruto
                using windows 7 pro 32bit. Installed new PA 11.60.22 and nothing show up on windows shell extension when right click on any zip, rar, etc. file. Have configure it in PA configuration but nothing show up. Please help?
                  Hey Naruto,
                  Please restart your computer and let us know if they come up
                  • NarutoN Offline
                    Naruto
                    no it’s not coming out by restarting my computer.
                    But, I think I solve the problem already by uninstalling PA and doing clean installation not updating it. If updating it the problem occured back. So I do clean install. Problem solve. Thanks Mili!
                      Glad it works now!!
                      Tested here, all ok
                        fixed, re-download please… thanks!
                        • skypxS Offline
                          skypx @spwolf
                          @Mili:
                          Glad it works now!!
                          Tested here, all ok
                          Thanks guys! It’s working just fine here. :D
                          AMD Ryzen 9 5700X
                          Samsung 970 EVO 2TB
                          GTX 3080ti
                          Win10 x64
