    PAstarter problems
    12 Posts 5 Posters 6.7k Views
    • P Offline
      plattejo
      installed latest version 1160rc3 and found that was unable to run backups, PAstarter locking up and having to close program via task manager.
      Removed software and rebooted, checked that no files had been left over and carried out a fresh install.
      PA runs Ok.
      If I go to create a new backup, when i go to select Destination Media - My Computer - software locks up.
      Uninstalled and installed 1160rc2 - able to see My computer but not able to run a backup without locking up.
      Uninstalled and installed 1150 all ok.
      Jon (plattejo)
      • moles42M Offline
        moles42 Alpha Testers
        Can confirm the crashing when creating a ‘NEW’ Backup script in Windows 7 Ultimate 64bit with PA 11.60.15
        it also crashes in Vista Home Premium 32bit
        Problem signature:
        Problem Event Name: APPCRASH
        Application Name: PABACKUP.EXE
        Application Version: 11.6.0.3
        Application Timestamp: 2a425e19
        Fault Module Name: PABACKUP.EXE
        Fault Module Version: 11.6.0.3
        Fault Module Timestamp: 2a425e19
        Exception Code: c0000005
        Exception Offset: 00568b71
        OS Version: 6.1.7600.2.0.0.256.1
        Locale ID: 3081
        Additional Information 1: 091b
        Additional Information 2: 091bcd57ae7af63c9dbe12c1a934b36b
        Additional Information 3: 7163
        Additional Information 4: 71637a8ad58f19fbd0c4efa3f7d0e910
        Windows 10 Pro x64
        Intel Core i5 3470 @ 3.20GHz
        8.00GB Dual-Channel DDR3
          thanks!! Got it.
            Socrates Banned @Mili
            I thought mine locked up as well. Then I decided to wait. and wait. After a minute and a half the appropriate window for selecting files appeared!
            Clearly a glitch. But it does work if you wait long enough,
            • moles42M Offline
              ‘Socrates’…it won’t work for me…it crashes and then gives me the error report and then closes PA immediately…it doesn’t give me an option to wait.
              Windows 10 Pro x64
                Socrates Banned @moles42
                Sorry. It appears our cases are different. But both appear at the very same point in the process.
                  @plattejo:
                  PA runs Ok.
                  Jon (plattejo)
                  RC3 has been updated to fix this issue with backup, as well as one reported issue with starter… we also changed bahind the scenes way adding folders works in backup (looks the same, isnt), so Plato’s mentor can check that out too :).
                  Since we couldnt update pa.exe this is available only via download page so you need to re-download PA Preview from download pages and see if it works fine.
                  • P Offline
                    plattejo @spwolf
                    Downloaded the updated RC3 version and installed.
                    Had to rewrite the backup scripts as the original scripts would not run.
                    New scripts run fine. No lock ups to report.
                    Big Thankyou for a very fast fix.
                    Jon (plattejo)
                      spwolf conexware @plattejo
                      @plattejo:
                      Jon (plattejo)
                      how do you mean rewrite? you had to re-create scripts? Can you send us one example of such script please? thanks!
                      • moles42M Offline
                        working perfectly for me now…thanks guys…:)
                        Windows 10 Pro x64
                        • P Offline
                          plattejo @spwolf
                          Found the problem with the backup script, ME !.:confused:
                          Some how during the process of running the script i managed to uncheck the add timestamp…
                          So no new file was created…
                          All working fine, this mornings backup ran without a problem.
                          Thanks for the quick response
                          Jon (plattejo)
                            ok :)
