    Context menu hot keys pt2
    4688
    • drteethD
      drteeth
      The underlined letters which appear in XP do not in Vista. I cannot find a setting to hide the underlining (IIRC there is one in XP).
      Regards
      DrT
      Using RC3.
        in vista they appear only if you hit conext key, that what you mean? its key next to the right alt, not sure how it is called officially :)
        TBGBeT drteethD 2 Replies Last reply Reply Quote 0
        • TBGBeT
          TBGBe @spwolf
          Right Alt <=> Alt Gr
          On my keyboard I have :-
          [Space Bar][Alt Gr][Windows][Context Menu][Ctrl]
          • drteethD
            drteeth @spwolf
            This does not seem to work in Win 7, retail version. Cannot get any underlined letters to show no matter what key(s) I press.
            DrT
              it is same as terry has written above - you need to activate shell extensions by pressing context key, then you will see underlined letters.
              • drteethD
                drteeth @spwolf
                Okay, I see how this works now, I was right-clicking and then pressing the key.
                Is there any way in these OSs to make the underlines appear permanently?
                Regards
                DrT
