    Encryption issue
    10 Posts 3 Posters 6.4k Views
    • moles42M Offline
      moles42 Alpha Testers
      I’ve noticed when trying to extract an encrypted file created in PA (latest build) that I get 2 different context menus when using Vista 32bit and Windows 7 RTM 64bit.
      I don’t get the option to extract in W7 but only to compress once again.
      see menus in animated screenshot below.
      Windows 10 Pro x64
      Intel Core i5 3470 @ 3.20GHz
      8.00GB Dual-Channel DDR3
        pae file or?
        • moles42M Offline
          yes ‘PAE’…sorry should have clarified that.
          Windows 10 Pro x64
            should be fixed in the next release
              11.60.15 is out via web update or download page, check it out and let us know how it works with this reported issue.
              • moles42M Offline
                no change guys…same as previous build.
                Windows 10 Pro x64
                • moles42M Offline
                  same problem in 11.60.18
                  Windows 10 Pro x64
                    spwolf conexware @moles42
                    @moles42:
                    didnt have time for it, yet :)
                      fixed in rc5?
                      • moles42M Offline
                        error code 2329?
                        what’s that all about guys I wonder…reared it’s ugly head when it tried to install the update.
                        I used the update via PA at first and then downloaded the latest release but got the same error code each time when trying to install.
                        solved
                        I had to uninstall the previous build before installing latest…and ‘YES’ the initial problem reported in this thread is fixed…many thanks Team…:)
                        Windows 10 Pro x64
