    Context menu hot keys
    7 Posts 4 Posters 6.7k Views
    • drteethD Offline
      drteeth
      Just a polite reminder; can the hot keys for the context menu items ‘extract to…’ and ‘extract to <folder>’ be made different please. Using latest RC2.
      Cheers
      DrT</folder>
        no need to be polite… be angry, very angry…
        • drteethD Offline
          drteeth
          Lol
          • H Offline
            Hagen @drteeth
            Release Candidate 2? I just installed Release Candidate 1. Where can I get RC2?
            Never mind. I downloaded RC2.
            • moles42M Offline
              moles42 Alpha Testers
              PA 2010 11.60 Preview 2 is up, you can download it from website or web update.
              http://dl.powerarchiver.com/2010/powarc1160rc2.exe
              Windows 10 Pro x64
              Intel Core i5 3470 @ 3.20GHz
              8.00GB Dual-Channel DDR3
                You can re-download Preview version (11.60.12) from our website. Please check it out and see if this solved your issue.
                • drteethD Offline
                  drteeth
                  Works a treat…thanks you very much.
