    Problem with the folder selection (Multi-Extraction)
    5 Posts 2 Posters 4.7k Views
    • J Offline
      Jochen
      when i use Multi-Extraction, click the folder-button, and then select one the last used folders (Screenshot1),
      this folder is not(!) selected (Screenshot2).
      I always have to select the folder directly in the folder tree (Screenshot3).
      This ist not very comfortable, because to select one of the last used folders is very much faster.
      Greetings!
        you need to press Go button next to the folder list, and it will go to that folder automatically (and it will be selected).
        • J Offline
          Jochen @spwolf
          no, that does not work…
          when i click OK after pressing the GO-button, there is no folder selected (in screenshot2)…
          the only way it works is to manually select the folder directly in the folder tree…
          in the old PA version i simply selected one entry of the last used folders and clicked ok…
            What OS are you using? thanks!
            • J Offline
              Jochen @spwolf
              Windows XP SP3
