    Context menu items problem
    5076
    • V
      vistamaniac
      It’s me again, I have another problem; didn’t want to make a new thread, but since my old one was closed :o….
      Well in PA 2010, there is an option in the config which enables “Mount as Virtual Drive” in the context menu. But when that option is enabled, the option doesn’t appear, even for ISO images. I have installed the drivers and everything, the mounter works, just that there is a not an option in the context menu, which is a real hassle because I have to go through a wizard just to get an image mounted. Thanks for any solution.
        i noticed this as well, it is recent bug… thanks.
        Also, new thread has to be opened for each bug :).
        V 1 Reply Last reply Reply Quote 0
        • V
          vistamaniac @spwolf
          Ah… right then thanks for the update mate.
          • ivanI
            ivan conexware
            it should be fixed in next update.
              please check following release:
              http://dl.powerarchiver.com/2010/powarc1160rc1.exe
              and let us know how it works now.
                p.s. ignore the version error for now, we need to update PAVD tomorrow.
                • V
                  vistamaniac @spwolf
                  it works great! thanks for that spwolf
