    External cd/dvd drive not working properly with PA Burner
    35 Posts 3 Posters 33.6k Views
      spwolf conexware @Hagen
      @Hagen:
      Uh…fellas? I’m still waiting for the build to fix the burner freezing issue. Although I’m able to burn using my internal DVD drive…doens’t mean this problem is fixed. I have an external DVD burner that I’d like to use for primary burning jobs.
      there is no magic wand we wave around here to fix issues. Be patient, and you will be informed via this forum thread when we have new build.
      thank you!
      • H Offline
        Hagen @spwolf
        thank you!
        Just thought I’d give you some eyebrow raising information about my further “adventures” in DVD burning using my external drive.
        I decided to double check just to make sure that there is something wrong with the burner software in PA2010.
        Well, I have good news…look at the screenshot. It says PA2010 successfully burned and VERIFIED 200 mg of data to my external DVD drive. But…
        I double checked using Directory Opus 9 to verify the contents of the newly “burned and verified” DVD I just put through PA2010. Guess what? There was absolutely NOTHING on the disc. Zero. Nada. I used the defaults in PA2010 and it went through the motions to read and “verify” my data and said my session was completed successfully. That’s what the screen grab shows in the attached photo. But when I checked to make sure it was true…there wasn’t anything there.
        When I hit the close button to the dialog box saying the burn session had completed? It froze PA2010 and I had to give it the three finger salute to close the application.
          You mean it froze PA Burner right? As those are two separate applications actually, closing PA Burner has nothing to do with PA 2010 itself.
          Seems like session info was not recorded properly in that case. We will know more once new burner is ready.
            please check following release:
            http://dl.powerarchiver.com/2010/powarc1160rc1.exe
            and let us know how it works now.
            • MarcFouM Offline
              MarcFou @Hagen
              @Hagen:
              It briefly recognized the external drive the first time I used it when I tried the first burning job. After the first burning job didn’t work…it no longer reads the drive for CD/DVD jobs.
              I just wanted to confirm I a similar issue with v11.50.61
              I got to 98% in the burning process, then gave an error (dont recall what it said). Ejected the disk and from that point failed to recognize any blank disk inserted.
              The OS also wouldnt recognize when a blank disk was inserted. Reboot didnt fix it. I had to unplug the drive, boot up into Windows, then plug the drive back in. Now the OS can see the drive and I can burn from the shell. Havent tried it again in PA.
              The file I was burning was a 1 GB ISO image. Vista Business x86 SP1. The drive is a Toshiba H653A.
              • H Offline
                Hagen @spwolf
                So far so good on my end. I need to test it on my external tomorrow before giving it a full thumbs up.
                  did you check with your external drive? We just added support for another burning method (SPTD) in PA 2010, in latest preview version. It is actually faster (20% in our tests it might be different) and lets multiple devices use burner at same time (which is problem with other burning methods).
                  It is automatically installed once you get latest PAVD update… let us know how it works.
                  • H Offline
                    Hagen @spwolf
                    I just installed the PA 2010 (latest build) today. I’ll test it to see if this works on my external burner.
                      @Hagen:
                      make sure you also install latest PAVD…
                      • H Offline
                        Hagen @spwolf
                        Something is wrong…I get an error dialog box saying “wrong Starburn.dll file”. What’s going on? And what is this PAVD thing you’re referring to?
                          @Hagen:
                          hm, check the dates on files:
                          PABURNTOOLS.EXE
                          Starburn.dll
                          in your PA folder. They should be 7.9.2009 and 13.08.2009 respectivly.
                          • H Offline
                            Hagen @spwolf
                            PABURNTOOLS.EXE
                            Starburn.dll
                            Actually I’m reading
                            PABURNTOOLS.EXE as 8.9.2009
                            Starburn.dll as 13.08.2009
                            So in conclusion…I think I’m using an even more updated version of PABURNTOOLS.EXE while Starburn.dll appears incorrect…because it’s not updated for the PaBurnTools.exe date. This is probably why I’m getting the error message when I hit the option VD button.
                              @Hagen:
                              when exactly do you get the error message?
                              • H Offline
                                Hagen @spwolf
                                Only when I select the Virtual Drive button.
                                  @Hagen:
                                  thats is fine, i thought you were getting it in burner because thats what we were talking about previously :)… just do the Web Update via Help, and you will get latest VD drivers which i talked about :-).
