    Not everything translated into russian
    4 Posts 2 Posters 3.9k Views
    • A Offline
      AlexandrSh
      Also not all elements are translated into Russian language.
      Here is the pic.
        is that the only thing you could find or?
        • A Offline
          AlexandrSh @spwolf
          Should be not “Empty”, must “Пустой”.
          And also instead of “New” should be “Новый”
          What is the “Separator”?
            if you redownload PA 2010 from download pages, you will get latest 11.50.66 version which fixes this issue (empty cant be translated at this time). Thanks!
