PA2010 Final: Virtual Drive installation not recognized
After installing PA2010 Pro German (Final 11.50.61) the Virtual Drive is not recognized.
This is what I did for a clean installation:
1. Uninstall PA2009 StarPort Drivers
2. Uninstall PA2009
3. Install PA2010
4. Download and install pastarport13001int.exe via PA2010PA2010 still says that the driver is not installed when I try to start a virtual drive. DrvInst.log in the PA installation directory (custom directory) says it installed successfully (attachment).
attachment_t_3963_0_drvinst.zip -
ok, do you have PAVD2010.exe in same folder? or?
currently there is problem with PAVD2010 installation - it always installs to default folder, so if you have custom folder for PA, PAVD2010.exe wont be there.
Yes, I can confirm this. PAVD2010.exe installed as a single file in its own folder at
c:\Programme\PowerArchiver\PAVD2010.EXE -
@Kai:
c:\Programme\PowerArchiver\PAVD2010.EXEok, so just copy it to PA folder and it will work fine.
Yes, indeed this workaround helps. Thanks!
btw this has been since corrected in installation and now works properly. Thanks.
