    SFTP Working, FTP … Not So Much
    16 Posts 2 Posters 12.2k Views
    • N Offline
      nameless
      PowerArchiver Pro 11.50.61 (Registered, ICIM)
      WinXP Pro SP3
      I have two FTP profiles: One using FTP, the other using SFTP. The target server is the same in each case.
      The problem is that while the SFTP profile works, the FTP profile does not. When I try uploading a file using the FTP profile, I get the error shown below. This error occurs immediately, without any delay.
      I’m using known-correct values for “Hostname or IP”, “Port”, “Username”, and “Password”. It makes no difference if I try using “Passive mode”, but (being familiar with my FTP server, router, and network configuration) it should work either way. Altering the “Default folder” also makes no difference.
      Using the exact same hostname / port / username / password in an FTP client, I can connect just fine.
        does ftp client work? (ftp window)
        • N Offline
          nameless
          I had not even tried that until now. Yes, when I open the FTP window and use the very same FTP profile that gives the aforementioned error, it works fine. It connects and presents a file listing.
          However, when I use the SFTP profile in the FTP window, PA freezes, even beyond the 30-second timeout that is configured! (Remember, in the upload dialog, the SFTP profile works!)
          To summarize, when trying to upload, the FTP profile gives an immediate error, but the SFTP profile works. When trying to simply connect in the FTP window, the FTP profile works, but the SFTP profile makes PA freeze.
            spwolf conexware @nameless
            @nameless:
            sftp does not work in client… so ftp upload does not work when sending from menu… thanks!
              can you also check ftp through backup please?
              • N Offline
                nameless @spwolf
                I’m sorry, but I don’t understand what you mean by this. :o
                  @nameless:
                  talking to myself i guess :).
                  SFTP does not work in FTP Client Window, just through file menu/shell/backup. Its on the list for one of the future releases.
                  • N Offline
                    nameless @spwolf
                    Doing a backup using the FTP profile works.
                    When I try the SFTP profile, I see strange behavior. When I select “FTP/SFTP” under “Destination Media”, then click somewhere else in the tree and then click “FTP/SFTP” again, I can see the “SFTP” profile flip back over to the “FTP” profile. I mean this literally–the drop-down list shows the “SFTP” profile at first, but after a split second, it flips to the “FTP” profile on its own.
                    When I select the SFTP profile and just proceed trying to create/upload the backup (without clicking away and back again as mentioned above), the upload seems to work (the file appears on the FTP server), but PA hangs on showing “Uploading filename.zipx”, and I can’t cancel it.
                    • N Offline
                      nameless @spwolf
                      Then it would be a good idea to remove SFTP from the drop-down list in the FTP window, so people don’t inadvertently make PA freeze.
                        @nameless:
                        yep… thats a bug really.
                          too bad you didnt check out these pre-release versions, we would have gotten this before final :)
                          • N Offline
                            nameless @spwolf
                            Yeah, sorry–I don’t normally use PA. I just install it every now and again to see if I want to switch to it…
                              @nameless:
                              its fine, we will do an update in upcoming week.
                                There is new internal release:
                                http://www.powerarchiver.com/test/release10/powarc1150.exe
                                that should fix ftp upload issue, please check it out. Not sure if we got them all (sftp is not removed from ftp window yet in this release).
                                • N Offline
                                  nameless @spwolf
                                  Wow, you guys don’t screw around! Thank you for getting this out, even though it’s not quite right yet.
                                  The FTP issue mentioned in the opening post is fixed. The FTP dialog… The one that appears when the FTP toolbar button is used… Works fine now.
                                  SFTP still shows up in the FTP window, and it still freezes PA, but you already know that. :)
                                  Thank you!
                                    if you redownload PA 2010 from download pages, you will get latest 11.50.66 version which fixes this issue. Thanks!
