    Virtual Drive doesn't work anymore
    3 Posts 2 Posters 4.8k Views
    • E Offline
      EricSch
      If I try to add a new DVD Virtual Drive, I get an error “Check StarPort driver failed! Check if StarPort or StarPort Lite is installed”.
      I reinstalled PA 2009 and PA 2010, but same error.
      Im using Win2008 SP2 64 Bit.
      How I get the driver StarPort again?
        Delete PAVD from you PA folder, and do then reinstall it by clicking on Virtual Drive in PA.
        That should make it work just fine.
        E 1 Reply Last reply Reply Quote 0
        • E Offline
          EricSch @spwolf
          Thanks, that did it.
