    Slow startup
    25 Posts 3 Posters 17.1k Views
      spwolf conexware @spwolf
      @Fafner:
      Tried this…I get the hang if I set PA to startup on that folder and if I double click on Archives stored in that Folder (I put 2 very small Archives into it).
      What I noticed is that I seem to get the very same hang while browsing to that Folder while setting it in PA options, at the exact moment when I click on the “Computer” icon (to make my drives show up). That doesn’t occur with any other application I have on my PC.
      The funny thing is that if I move my Archives to the default folder “My Documents”, I don’t get the hang (keeping PA set to a fixed startup folder).
      hm, something like that happened to me - i had AVG installed on our test computer Vista 64 bit (disabled), I uninstalled it so i can install Avast and after i restarted everything worked fine, even with avast installed and working.
      When was the last time you restarted that computer?
      F 1 Reply Last reply Reply Quote 0
      • F Offline
        Fafner @spwolf
        I restart it on a daily basis…
        • drteethD Offline
          drteeth @spwolf
          yeah, as i said, it is two completly different problems.
          Any news on this issue since I reported back on the test file?
          Cheers
          DrT
            spwolf conexware @drteeth
            @drteeth:
            Cheers
            DrT
            nope, we will have to rewrite something once final is released. Annoying issue :)
            • drteethD Offline
              drteeth @spwolf
              Feel free to contact me to test any fixes.
              Cheers
              DrT
