PowerArchiver 2010 Help
Why do I get a Program Compatibility warning when I close PowerArchiver 2010 after viewing the PowerArchiver website within the PowerArchiver help?
That is working ok on my computer.
Adobe flash problem maybe ? -
I have Adobe Flash Player 10 installed.
So far I have been unable to re-produce.
you shouldnt try to surf the web from inside PA help… i dont think IE allows everything inside help hence it might not allow all plugins.
