    Power Archiver 2010 b3 doesn't compress to cab
    7 Posts 4 Posters 5.6k Views
    • Y Offline
      yoniy0
      On Vista Ultimate 64-bit, the shell command of “compress to cab” operates as “compress and FTP”.
      It might be worth mentioning that PA2009 behaved the same on my computer.
      EDIT: it is possible to create cab files from “compress with options”
        @yoniy0:
        On Vista Ultimate 64-bit…
        Hmmm, works for me on Win XP SP3 (32bit).
        @yoniy0:
        Again, works for me on Win XP SP3 (32bit).
        • moles42M Offline
          moles42 Alpha Testers
          fine in vista 32bit for me…problem has to be the 64 bit once again I would figure…:(
          Windows 10 Pro x64
          Intel Core i5 3470 @ 3.20GHz
          8.00GB Dual-Channel DDR3
          • Y Offline
            yoniy0
            That’s my guess too. Since the new version is in beta stage, I figured it’s as good a time as any to mention this issue. Is there somewhere else I should post this problem?
              spwolf conexware @yoniy0
              @yoniy0:
              thanks, this is the best place!
                please check pre-RC1 release:
                http://www.powerarchiver.com/test/alpha115/powarc1150rc1.exe
                and let us know if this has been fixed :).
                Y 1 Reply Last reply Reply Quote 0
                • Y Offline
                  yoniy0 @spwolf
                  Yes, now it works fine.
