    Problem with "Sort By" Options
    7 Posts 4 Posters 5.0k Views
    • L Offline
      LukeFF
      Much to surprise, with the latest beta, I am noticing that clicking on the various “sort by” option tabs (Path, Date Modified, File Type, etc.) are causing PA to automatically extract the contents of the file, without any further input from me. Is this a bug, or did I miss a new feature release? :confused:
      • moles42M Offline
        moles42 Alpha Testers
        I’d guess it’s another bug Luke…to go along with this one…http://www.powerarchiver.com/forums/showthread.php?t=3677
        although I’m not able to recreate your reported problem.
        Windows 10 Pro x64
        Intel Core i5 3470 @ 3.20GHz
        8.00GB Dual-Channel DDR3
          @LukeFF:
          it happens for me if you try dragging the column… not just clicking. Is this what you are seeing?
          I saw it once, forgot to enter it into our system
          • L Offline
            LukeFF @spwolf
            No, I’m just trying to click on the tab, not drag anything (e.g., click the “Path” tab, and it causes PA to start extracting the contents of the file).
              Mili conexware @moles42
              @moles42:
              This should be fixed for the next release :)
              Also cannot reproduce Luke’s issue, works fine here when clicking on Path tab.
                Please check beta 3 via web update or download page and let us know if this issue has been fixed… thank you!
                  this should work properly now? if not, pm me… closing it.
