    'Sort By' issue
    9 Posts 4 Posters 6.2k Views
    • moles42M Offline
      moles42 Alpha Testers
      I found in Beta 2 that if you use the ‘Sort By’ option with your left mouse button as indicated in screenshot 1 and you leave your mouse on this area then PA hangs indefinately until you move the mouse away.
      using the right mouse button option and selecting your ‘sort by’ choice works fine.
      another thing I noticed is that PA flashes briefly when using the first option and reveals an ‘extracting files’ box behind the main GUI before returning to the foreground.
      please see attached screenshots.
      Windows 10 Pro x64
      Intel Core i5 3470 @ 3.20GHz
      8.00GB Dual-Channel DDR3
        yep, thanks moles!
          Please check beta 3 via web update or download page and let us know if this issue has been fixed… thank you!
          • moles42M Offline
            it’s still hanging in beta 3 when the mouse is left on the ‘sort by’ section but I’m not getting the ‘extracting files’ box behind the main GUI anymore so at least that’s one area fixed.
            Windows 10 Pro x64
              ah, now i understand the sort issue
                ivan conexware
                thanks, the issue should be fixed in updated b3.
                  .41 is up on download page so downlad it and give it a whirl, it should be fine now.
                  • moles42M Offline
                    excellent work guys…works perfectly now… :)
                    thank you.
                    Windows 10 Pro x64
                      np
