    PA 2010 archive path information issue
    5 Posts 2 Posters 4.1k Views
    • drteethD Offline
      drteeth
      Using latest build.
      I am trying to extract an archive using the paths in the archive.
      The path has a leading ‘.’, so it looks like this “.rockbox\rocks>”. This dot is visible in PA and the extracting files dialogue.
      In this build, the leading dot is missed off on extracting so the extracted path becomes “\rockbox\rocks>”.
      PA 2009 worked fine.
      Cheers
      DrT
        format? zip?
        • drteethD Offline
          drteeth @spwolf
          format? zip?
          Apologies for missing that, it’s a ZIP file.
          Cheers
          DrT
            Beta 2 is out, please check it out via web update or download page. Thanks!
            • drteethD Offline
              drteeth
              Issue fixed - thanks.
              When are the graphical issues under XP to be fixed? I posted a screen shot in another thread.
              DrT
