    PA 2010 Beta - "Newer Than …" Problem is Back
    5 Posts 4 Posters 5.3k Views
    • J Offline
      Joe Schlepp
      A problem already fixed in the PA 2009 Backup function has returned: the “newer than” option under Time and Size Filters is not working at all. It currently produces the same results as “of any time”.
        ok, thanks a lot!
          Beta 2 is out, please check it out via web update or download page. Thanks!
            working fine here, anyone else?
            • moles42M Offline
              moles42 Alpha Testers
              tested and working fine for me also.
              Windows 10 Pro x64
              Intel Core i5 3470 @ 3.20GHz
              8.00GB Dual-Channel DDR3
