    Switching Interface doesn't restart
    13 Posts 3 Posters 7.2k Views
      After upgrading to PA 11.50.30, I noticed this problem.
      So I uninstalled - reboot - installed.
      On opening (unregistered) in classic, the choose interface dialogue appeared; I chose modern and PA restarted correctly.
      After entering registration codes, switching interface from Modern to Classic and PA shut down, but did not restart automatically.
      Restarting it was in Classic and switching from Classic to Modern, again PA shut down but did not restart.
      So the interface switch is being applied, but PA does not restart automatically.
      • moles42M Offline
        moles42 Alpha Testers
        just confirming that it also happens in vista home premium.
        Windows 10 Pro x64
        Intel Core i5 3470 @ 3.20GHz
        8.00GB Dual-Channel DDR3
          TBGBe @moles42
          Thanks for checking.
          (And for editing - had me worried for a moment :D )
          • moles42M Offline
            just did more testing…
            I find it now only happens to me when I’m using the explorer view…see screenshot.
            if I don’t use that view then it reopens immediately.
            Windows 10 Pro x64
              nice, thanks
                cant reproduce it anymore, anything else specific (steps) that could help us reproduce this please?
                  TBGBe @spwolf
                  Start PA; it is using classic default (Preview amd folder open) - see screenshot.
                  Select menu : View/Toolbars / Modern
                  PA closes and does not restart.
                  Start PA from Start Menu - Modern Blue (with folder & Preview) is active.
                    send me your zipped reg please, still works fine here.
                      there was an reason I said email, not post here!
                        TBGBe @spwolf
                        Sorry, didn’t read it as email. :(
                          spwolf conexware @TBGBe
                          @TBGBe:
                          its fine, terry… hopefully not so many t.b.'s are using PA now :-)
                          • moles42M Offline
                            seems to be working fine in beta 2 for me.
                            many thanks.
                            Windows 10 Pro x64
                              TBGBe @moles42
                              Yes, with Beta 2 (11.50.37) PA does restart after switching interface.
                              (Previous problem losing Q.A.T. is back however - I’ll put that in different thread).
