    Problem ejecting rocket
    • C
      corneliusmixon
      I dont if Power Archiver is supported on windows 7 beta x64 build 7048. If it is supported, my problem is that I get an error when I try to unmount ISOs. I get the error message: "Problem Ejecting ROCKET DVD-Rom F50 SCSI CdRom Device This device is currently in use. Close any programs or windows that might be using the device, and then try again."I am sure I closed all programs and processes that in use. Thanks for the help.
        thanks, we will check out, quite possible something that might need tweaking due to some Microsoft changes or maybe they will fix it too.
        It seems that adding another mount works (even though it shows similar error at first).
          looking at 7057 build, it seems they fixed the issue… I get no errors when i remount the device anymore.
