    Icon issue in build 11.50.23
    14 Posts 5 Posters 10.0k Views
    • C Offline
      Cristian
      Hello, I’ve reported the issue here.
      It’s still there in the latest build. :(
      Win 7 build 7048 x64.
        i know, i was told it was fixed for sure and tested
        it will be fixed in beta 2… for sure :-)
          Are you referring to the background in Shell (context) menu?
          As discussed in
          http://www.powerarchiver.com/forums/showthread.php?t=2948
            ivan conexware
            Hm, I tested with vista x64 and xp x64 and worked fine. Can you please check what is the version and a date of a PASHLEXT.DLL in Program files’ directory?
            • C Offline
              Cristian @ivan
              @TBGBe:
              As discussed in
              Yep, that one.
              @ivan:
              • C Offline
                Cristian @Cristian
                Still not fixed in 11.50.30.
                • F Offline
                  Franky
                  Hi there, here is Franky again. I’ve to agree to Cristian. The transparant background problem is still not fixed with Windows Vista x64.
                  I’ve installed the lasted 2010 Beta 1 refresh. (11.50.30) :-(
                    yeah, not fixed yet… it has same image, but apperantly it works differently in 32bit and 64bit.
                    It was lower on the priority list so we didnt take an look at it yet.
                      just an update, it is the same for beta 2… apperantly for x64 very differently than for 32bit version, so you will need to be patient a bit… it seems that we need to manually paint the resource via GDI which is a lot more work than simply putting icon with proper transparency which we do for 32bit.
                      • F Offline
                        Franky
                        Still the same problem with 11.50.41. :-(
                        Will it be fixed with the RC or Final version? I hope so.
                          please check pre-RC1 release:
                          http://www.powerarchiver.com/test/alpha115/powarc1150rc1.exe
                          and let us know if this has been fixed :).
                          • F Offline
                            Franky
                            Yes, now it looks great. No more white background!
                            When there will be the real RC1 with German language?
                              we are waiting for 2 more fixes before real RC1
                              thanks… it was insanely hard to make it work properly as it is completly different from 32bit version…
                              • C Offline
                                Cristian @spwolf
                                Thanks for you effort.
                                It’s ok now! :)
